When to Install Board and Batten Siding
If you are planning a siding job for your home, you may be considering using board and batten siding. There is a range of siding styles and choices for you to consider, each of which has distinct advantages and disadvantages.
What Is Board and Batten Siding?
Board and batten siding is a distinctive style of siding that provides a historic and unique look. Board and batten siding is designed to create a vertical look with the siding boards, where the boards are separated and have narrower boards in between them covering the joints. The appearance of a board and batten sided home is very distinctive. The siding has a smooth under layer of boards with narrow boards on top, creating a crisp vertical channeled look on the outside of the home.
When to Use Board and Batten Siding
If you have a historic home, you may choose to use board and batten siding to keep the historical appeal and integrity of the home. Rustic homes, ranch homes, cottages, and country style homes are also a great place to use board and batten siding. The distinctive appearance of this siding lends itself well to historic, country, and rustic appearing homes.
This siding choice is very affordable. Many people choose to save money on siding when covering a garage, barn, or storage building. The cost efficiency and durability of board and batten siding make it an easy choice for many homeowners needing to cover a home or building. Without weatherproofing material, board and batten siding is not as weather temperate as traditional horizontal siding. Without additional weatherproofing, it is best used in non-extreme and mild climates. Since the siding is vertical, you cannot nail it directly to wall studs of a home or building. Instead, solid sheathing or boards must first be applied and then the board and batten siding applied to them. When a weatherproofing material is applied in between the wood sheath and the siding, full weatherproofing can be achieved.
Maintenance
The design and application of board and batten siding allows homeowners to replace sections of the siding when repairs are required. Unlike other types of siding, individual boards or sections of the siding can be removed and replaced when required. This feature helps keep the cost of replacement and upkeep lower than other types of siding. If this siding is well maintained, it can last a lifetime. However, if this siding is not properly maintained, it can crack, split, warp, and rot causing damage to the home.
Overall Advantages
Board and batten siding creates a distinctive historical or rustic appeal to homes where this aesthetic is desired. The installation is relatively easy and this siding option is inexpensive when compared to other siding types. When properly maintained, board and batten siding is very durable and will last longer than other types of siding. Board and batten siding is an appealing option when you consider that the initial cost is low, the durability is high, and the maintenance costs are low as well.
