White Bedroom Decorating: The Zen-like Approach
To create a tranquil and peaceful space in which to begin and end your day try white bedroom decorating. When you choose a monochromatic white color palette to decorate your room you aren't tied down to matching furniture or accessories. By painting everything white you will create a uniform look that is zen-like in its simplicity.
Paint, Paint, Then Paint Some More
Paint everything in your existing room white. Start with your walls and windowsills, and then move on to your furniture. Your headboard, dresser, nightstands, and entertainment center should all be white. Even if your furniture is crafted in several different styles or if it comes from different design schemes painting everything white will tie it all together. Do not leave a surface unpainted. When you are finished your room will look like a fresh canvass.
Minimal is Best
In a zen-like environment minimalism is best. Don't overdo it with pictures and knick-knacks. Instead, consider green aspects and tranquil pieces. A small water feature adds a peaceful ambiance. In addition, plants such as bamboo give an open and inviting appearance. Use small pieces to decorate your room, but keep the choices you make vibrant. Small splashes of color will refresh your room while allowing you to rest peacefully.
