Window Insulation
When you purchase a new home, you may have to put some thought into window insulation. New homes often come with insulated windows, albeit cheaper and less effective than others you can purchase. But older homes generally have windows made with one pane of glass. Besides purchasing insulated windows, you can also add treatments to help insulate them. This article will share with you some important information about window insulation, including possible tax credits.
Why You Should Bother with Window Insulation
In this day of high bills and a slow economy, every penny counts. When you set out to heat and cool your home, you could be throwing away money every minute because your home is not properly insulated. Lack of insulation may result from a poor selection of windows or even window treatments.
Window insulation will help you save money by reducing your heating and cooling bills. Purchasing window insulation is an investment that will reap its rewards over the years. If you ever need to sell your home, you will also be increasing your property value. Using window treatments as window insulation can give your home a beautiful look inside as well as on the outside. Some other benefits that may not be as obvious include energy conservation and reduction of exposure to harmful UV light.
Window Coverings as Window Insulation
One of the most popular types of window coverings is cellular or honeycomb shades. These chambers or cells in the shade trap cold air and decrease the amount of cold air that enters your home. The shades also lessen the amount of hot air that is drawn toward the windows.
Window quilts protect against air and moisture. The moisture-tight fabric has four-sided seals. You can also modify regular draperies and Roman shades to be used as window insulation if you add thermal lining.
Wood shutters offer some protection from the elements. Using one or more of these window coverings will decrease the energy you need to heat or cool the home. If cost is a primary factor for you, consider thermal insulation foam board. The boards are typically pink or blue, but you can cover the outside with fabric to match your drapes. Place these over the windows on the inside at night and remove them in the morning.
Tax Credits for Window Insulation
The government will often provide tax breaks and credits for many things which save resources. The problem is they rarely advertise credits, and it is up to you to find out for yourself. In the United States, if you put money into energy-saving products, you may be entitled to a tax credit for 30% of the cost up to $1,500. Check with your local tax provider for specifics relating to your unique situation.
