Wood Carport vs Metal Carport
A wooden carport is a common feature in many homes. It is an outdoor structure that consists of a roof and open sides. This makes convenient storage space for a car, recreational vehicles, boat or truck. It provides sufficient protection for your vehicles from the elements. The port may be a stand-alone feature or could be attached to the main house or some other building. It is usually located in front of the home. However, you may also choose to have it at the side or in the backyard. Wood and metal are commonly used to construct the structure. Below is a comparison.
Wood Carport Advantages
Wooden ports are easier to construct than metal. This is partly because of the lightweight nature of wood which makes it easier to work with. Wood is also softer than metal which allows you to cut, shape and joint much faster. The ease of assembly for wooden ports helps to make these more affordable than the metal type. Due to the soft and lightweight nature of wood, you get more flexibility when it comes to design. Wooden ports also add to the natural appeal of your outdoors. This enhances the outdoor ambiance. It is easier to undertake repairs on wooden ports due to its soft and lightweight properties compared to metal.
Disadvantages
Durability for wooden structures isn’t as high as metal. Unfortunately, continued exposure to the elements is not without detrimental effects on wooden ports. Temperature fluctuations and wet weather take their toll on the structure. Wood also has a high susceptibility to rot. These aspects contribute to the high maintenance nature of wooden outdoor structures. You need to paint or varnish regularly to protect from the elements. In the event of a fire, your wooden port is certain to go up in flames since it’d provide fuel for the fire. Metal, however, can be salvaged as it does not burn.
Metal Carport Advantages
Metal offers the highest durability for outdoor vehicular storage. Whether you choose aluminum or steel, the structure will remain in place for several years. The high resilience and stability of metal further add to the longevity of the structure. Metal structures do not easily break, dent, chip or split, unlike wood. Metal is also extremely resistant to mold, termites, bugs, and rot. The detrimental effects caused by nature are minimal for metal ports. Additionally, in the event of a fire, you’re certain to redeem your metal structure, unlike wood. Metal outdoor structures have lower maintenance requirements than wooden structures. You need not paint or varnish regularly as is the case with wood. Due to its high resilience, greater durability and low maintenance requirements, a metal carport adds to the value of your home.
Disadvantages
More effort and time are involved in construction which adds to overall costs. Your design options are limited to metal due to the hardness of the material. Although metal is more durable than wood, rust and corrosion are common with metal. These spoil the appearance of the structure. To guard against rust and corrosion you must apply a protective coat periodically. This adds to your overall costs.
