Wood Panel Siding vs Wood Lap Siding
  • 4-100 hours
  • 0-5,000
Before you make your final decision to wood panel siding in your home, you should definitely consider all of the different types of wood siding that are available. After all, one type of siding may be the best fit for your specific needs. What follows should help you to decide between wood panels and wood lap siding.
Panel Siding
Panel siding can come in many different shapes and sizes. The standard width for panel siding is four feet, and it normally comes in lengths of eight, nine, or 10 feet. The width can vary. Panel siding can be easier to install than lap siding due to its simpler nature.
Lap Siding
Lap siding can come in a wide variety of types. If you are looking for a way to customize your home's appearance, you might want to take a look at long wooden lap boards or even ship lap siding, as well as the many other kinds of lap siding.
Ultimately, the main differences between wood panel siding and lap siding are aesthetic in nature. Both types of siding will look great and give your home a rustic feel but will have the drawback of being vulnerable to damage from moisture. As you have chosen wood siding, aesthetics are probably quite important to you, so it is a good idea to find examples of not only the overall type of siding you want, but the specific style, and find out which one would fit your home best.
