Add Beam Support
$50
5 tools
This project is about lifting and supporting the sagging main beam in a crawl space under an older home. The floors at one end of the house were sloping towards the center and also downward to a point about six feet from the end of the house (a low spot). A tight string from the outside walls across the area showed it to be an inch low. Inspecting the area from underneath showed the main beam had developed a crack and was sagging. It needed to be raised back to level and supported. Having no experience with a project like this I posted to one of the forums asking if it was a DIY project and seeking advice. As you can see I decided to do it myself. The forum thread has more details and can be viewed at: http://forum.doityourself.com/framing-sub-flooring/407140-adding-main-beam-support-crawl-space.html
TOOLS
Form lumber 6 bags concrete 8 feet of rebar Cement blocks 1 sack mortar
Proud of a Project?
Inspire others with your work.
