Log Home Interior Finish
dreammoney
Member • Cumby, TX
$30000
19 tools
This project consist of the interior finish on a Satterwhite Log Home shell. Videos of the home being erected can be seen on http://youtube.com/user/mayosdream Progress photos as well as update information can be seen on http://buildingyourdreamhome.us/interior.htm The interior stud walls are ready for insulation and finish. Plumbing, electrical, and HVAC has been completed as far as possible until walls are closed. The completion will not be accomplished quickly as I will be doing most of the work without assistance. The first floor will be porcelain tile throughout and will be completed by a tile contractor who will also install a tile shower in the bath. Custom cabinets will be built and installed by an outside contractor as will the countertop. Insulation has been installed in most of the downstairs stud walls for sound deadening. The ceiling and loft floor will receive R19 to R30 insulation. I will be installing 1x6 or 1x8 T&G planking on all walls and ceilings. A scaffold system will be required to install ceiling planks in the vaulted ceiling. I will also be fabricating an enclosure for the fireplace chimney and installing a mantle.
TOOLS
Countertops R13 R19 R30 insulation 3300 LF 1x6 T&G Aspen 900 LF 1x8 T&G Ponderosa Pine 1360 LF 1x6 T&G Ponderosa Pine 690 LF 1x8 T&G White Pine 1 ea 9"x22&#039peeled spruce log 6 ea 7"x20&#039peeled spruce logs 10 gal Lifeline Interior Butternut stain/sealer 6 gal Acrylic Satin topcoat 300 sqft Brazilian Teak Hardwood Custom Cabinets Tile Flooring Tile shower Plumbing fixtures Kitchen appliances Miscellaneous interior trim
Proud of a Project?
Inspire others with your work.
